Slice input as screen
More of a question than a bug.
I can only route an entire screen to a slice if that screen is set to virtual output.
Can you not output an assigned output screen to another screens slice?
(example: Got a funky pixel map with stuff all over the place, and I want to send that output arrangement to a clip source that I can preview)
Re: Slice input as screen
Arvol wrote:Can you not output an assigned output screen to another screens slice?
Indeed that's not possible.
The outputs are drawn directly to the Screens, they are not present as a temporary texture that could be used in another slice.
This would require another renderpass.
What you could do would be to switch your pixelmap's screen to virtual, then create a new Screen that would drive your output with the pixel map's virtual screen routed to a single slice.
This way you could use the pixel map texture in other slices too.
