Shaper and Dashboard incompatibility
VJ_io
Post by VJ_io »
I seem to be unable to take parameters from Shape 1 and Shape 2 and make dashboard controls from them. The other parameters in Shaper work however.
Re: Shaper and Dashboard incompatibility
You should be able to take the size parameter from Shape 1 or 2 and assign it to dashboard dials but the types will need to be used with a keyboard, OSC, DMX or MIDI shortcut.
VJ_io
Post by VJ_io »
I am unable to do so. Can I get confirmation that it's possible to do so?
You need to open Shaper 1/Shaper 2 and select the size parameters.
Indeed it looks like it's broken, I created a ticket. #11174
