Since I use Resolume Arena 6 I have this wierd bug that I can't rick-click on the layer name.
It still shows the rick-click layer properties window but only for about one second before it disappears.
Updating or reinstalling didn't help.
Does anyone have the same problem or know how to fix this?
I would appreaciate any help.
I'm using a Mac, IOS 10.11.6
Rick-Click on Layer
Re: Rick-Click on Layer
That probably comes from using BetterSnapTool but you can easily turn it off a specific application so do that for Resolume and you should be fine.
As an alternative you can use a different app. I switched to Magnet and haven't had any issues.
Fluegelwolf
Awesome, that was really the problem. Thank you so much!
