This would achieve two things:
- 1) allow to make solid color clip with color matched with any LED instrument in the light plot
2) use resolume fixture color back in the composition as a variable solid color clip
How would Resolume be able to sniff out the start channel and colour space(rgbw, rgba) from artnet? RDM? Or would you create the paper work in Resolume?Oaktown wrote:I would love to see a new Artnet Color Source that would function just like a reversed 1x1 fixture with all the information (Color Spaces, IP, Subnet,Universe, and Start Channel).
So just more documentation then manually mapping RGB add subtract to a solid colour?Oaktown wrote:No sniffing, just drop down menus. Think of it as a source fixture that gets it’s color from artnet input.
I realize TD is one approach but having it as a built in source would simplify the process and economize resources.
im interesting with being able to create a solid color source with color space data from either a light board or from a Resolume fixture. This would be similar to using the color picker except with Artnet Data.So just more documentation then manually mapping RGB add subtract to a solid colour?
I’m more interested in a source than an effect but either could work.That actually may be a good starter project for someone to create an effect, just a series of panels and then you manually map the artnet to.
either Resolume mapper or DMX info.I'm just finishing up a touch designer program for EDC but maybe this would be a good starter program for me to learn on. Effect that creates solid white with just useful drop downs in Resolume. Then map with Resolume's mapper.
TruthJoris wrote:Insert meme of that little boy from Transformers being all manly flexing his muscles and spouting Nike slogans here.
