Hi everybody!
I'm new, but already have visit the forum (a lot) for tips and help, so thank you for your help!
I saw a recent subject about compatibility on Mac and PC. I have a problem with this actually : a friend (MAC) tried to send me an .avc file (Arena 4) but when I try to open it it say "XML parsing of composition "..." failed". I can't find clear informations about it and I'm total newbie... Does it mean he need to send me another file with the .avc ?
Thanks in advance
Transfer between Mac and Pc [SOLVED]
Re: Transfer between Mac and Pc
Opening Resolume 6 compositions will display this message when you try to open them in Resolume 5.
Resolume 5 can't open Resolume 6 compositions.
Or the file got corrupted in transit.
Thanks for your answer zoltan
I already try both of possibilities... We both work on Resolume Arena 4, and first time, the file was totally corrupted because, probably, of a broken external harddrive.. But second time he sent it to me by e-mail and I check the file it's clean. On his side everything the file works.
Is it possible that my Resolume Trial license is the problem?
I try today to send it to another Mac user for a test...
If you are sure the file works on the senders side you could upload it here(zipped) and we could have a look at it on our end.
The unregistered version works the same way as the registered, so that won't be an issue.
Hello !
Problem solved ! there was an issue with the versions (5.1.3 and 5.1.4).
Sorry it's so dumb
Thank you for your time
Sorry it's so dumb
