Live Audio / Voice
floSchwarz
Live Audio / Voice
Post by floSchwarz »
Hey Guys,
Thank you for Making These wonderful working Software and for having me in this Forum.
I want to add Live Voice to my visual Show via the Focusrite Scarlett (a xlr to USB Hub) but i dont know how to do it. I cant select it in the Source Section Like my Elgato Cam Link because it doesnt appear there. In the Audio Options i can select it as my Main Audio Input but i dont know how to activate it so that i can speak live to my Visuals. I am Sure there is a very simple way to do it but i can't find a solution.
I am very grateful for your Help
Greetings from Germany
flo
Re: Live Audio / Voice
Resolume doesn't support audio inputs as sources for mixing in the composition.
You can only use the external audio inputs as source for FFT and SMPTE.
To use the input as FFT you need to select the input channel in Audio preferences:
