I am having this problem consistently: basically I can load 4 or 5 decks, but then the following decks won't load.
If I select the deck in the list, and try to load it, the name of the deck in the tab will change, but the clips will not load. The limit seems to be about 4 or 5 decks before this starts happening. The decks that won't load *will* load correctly if they are loaded first.
Exiting and restarting Resolume seems to fix this, some of the time.
decks stop loading
- gpvillamil
