continuous play sync between clips
stanleystark
Post by stanleystark »
it would be great to be able to sync several clips at the start point... (i think this would work better with same size clips.. but should also work with different lenth clips)..
this would allow you to change to other pre-produced clips that look almost the same, but with some changes... For example an animation with certain elements more than the first clip... then you play addition of elements without having a time break in the clips :D
stanleystark
to illustrate this idea.. think of the kylie minogue video for come into my world (i think that's it) where a robotized camera was used to make exactly the same movements over and over allowing then in post production to overlay different times resulting in a great dream come true... more kylies.. :P The idea(using the kylie example) is to add kylies with using the notes.. more or less
