pal to ntsc
kris_
Post by kris_ »
YES.... i probably have a gig in NY... Small detail, I live in belgium... Does anyone knows a way to do all my stuff in pal; two laptops, a dvd player, a MX 50 and convert the signal in to NTSC... All help apriecated
ether_
Post by ether_ »
Hi Kris
- If you're taking all you're own gear, you can use your normal setup - the only thing would be to check the mains power details, and get an adapter if required.
ether_
Post by ether_ »
Also, if you're hiring a projector over there - check it takes a PAL signal (most take both).
you laptop can probably output both ntsc and pal, so only bring you laptops and have the club rent an mx-50 for you (which is not too much to ask)
mikael_
Post by mikael_ »
or get the club to rent a scan converter to convert your output from your mixer to ntsc
/mikael
