Avoid apc mini or apc key 25 for resolume
sufan8888
Post by sufan8888 »
Done some extensive research over the World Wide Web.
The real reason (I believe) why Apc Mini or Apc Key 25 doesn't have full color response (which is possible technologically) in Resolume is that Akai wants us to buy the more expensive Apc 40 MKii...
So avoid these two that are designed for Ableton Live musician if you are destined to be a VJ. A VJ should use VJ weapons, such as Apc 40...
Re: Avoid apc mini or apc key 25 for resolume
Which one of these do you have that doesn't work for you?
