record problem
rosasdipietro101
record problem
Post by rosasdipietro101 »
when i record something and then play it, it goes much faster then i first saw in my preview window. i think it will be the same when i use another monitor on full screen. but haven't tried it yet...
what can i do about this???
btw i have radeon 9600 SE
resolution 320*240
i use after effects mostly
Re: record problem
Which Resolume version are you using?
Are you recording with audio?
Is the clip loaded in timeline or BPM mode?
What is your composition speed and BPM set to?
