trigger clip on different deck
aftermathematic
Is it possible to (midi) trigger clip that is on another deck?
Re: trigger clip on different deck
Don’t believe so. Clips are not loaded until a deck is clicked on, you’d have to do two steps, one to select the deck, then another to select the clip.
