I keep losing the ability to trigger multiple clips with enter
TVsVeryOwn
Post by TVsVeryOwn »
I control click the name handles to select the clips I want, hit enter, works first time. Eject all layers, try again, enter does nothing. Restart Resolume, works again, one time.
Re: I keep losing the ability to trigger multiple clips with enter
Works fine for me.
Could you try aligning the clips you want to trigger simultaneously into the same column and try column triggering until you get a fix?
It works for me as well on MacOS.
Are you sure you don't have conflicting keyboard shortcuts?
Also, as a reminder, if you are on a Mac, you would use Command not Control to select multiple clips.
TVsVeryOwn
This is on Windows 10. I don't understand how a conflicting shortcut would allow me to do it one time and then stop.
TVsVeryOwn
Demonstration video:
https://youtu.be/gMdGYTv2IG8
This time it took a couple cycles to break completely, but I can't find a way to bring it back without restarting.
I could recreate this.
Looks like you can't launch a clip with Enter again when you launched it before with Enter.
I'll create a ticket. (11334)
