Bug when Midi is connected
nightjar84
Post by nightjar84 »
Hi there,
When a Midi device is conected and mapped (also the column forward and backward) if i use the mouse to switch column I sometimes have to clicl twice to get the column selected
Also: the midi controlled column switching is often not working, ie. the UI switches to the next column though Arena keeps playing the same clips.
Re: Bug when Midi is connected
...does this happens on both of your systems...mac an windows?
This sounds like a bug that was fixed on the 6.0.6 release. Which Resolume version are you running?
