What about having config files for MIDI assignments ??? some kind of ini file you can save when configuration is ok... and that you can load when needed...
very usefull if you have more than one MIDI keyboard or more than one control surface...
As for me sometimes i go to giggs and i use a provided keyboard wich isn't configured the same way than mine... i have to change resolume's configuration or adapt the keyboard to same channel and CC as mine... very annoying...
thanks...
