Live Feed Capture Card Distorted Image
katday
Post by katday »
Hi All,
Not sure if this can actually be fixed, but I'm using a canopus advc110 (composite to thunderbolt) into Resolume Avenue 6 and its showing a strange diagonal distorted image. As you can see from the screenshot it won't let me choose a format and obviously 0 x 0 pixels is not going to work.
Strangely, this capture card does work when using VLC player and Syphoner into Resolume. It could just be that this capture card doesn't work with this version of Resolume Avenue, as I can see from past forum posts years ago that it has worked with Resolume fine.
Any insight would be great!
The attachment distorted.jpeg is no longer available
Re: Live Feed Capture Card Distorted Image
Looks very similar to a ticket we're working on regarding a DV - Firewire capture.
I've attached this to our ticket. We'll look into it.
Are you on mac or windows?
katday
Post by katday »
Thanks Zoltán, I work on a Macbook Pro late 2015 13".
katday
Post by katday »
p.s. it is DV/firewire into the thunderbolt adapter into the port on my macbook.
katday wrote: Sat Jun 30, 2018 12:45 p.s. it is DV/firewire into the thunderbolt adapter into the port on my macbook.
Yeah, then it's definitely the same issue.
