So basically i got the MSI GT 75 8RG
i9 processor
GTX 1080 8GB
32 GB RAM
so now the problem is when i trigger clips it gets stuck for a second or something which is noticable and it plays off even other visuals which are already triggered also gets stuck even when i select another clip from another layer.
Please help me out
Most clips are dxv 3 the remaining are dxv 2.2
I have uninstalled nahimic also
Please help
MSI GT 75 8rg clip trigger issue need help
DOPETICAL ILLUSION
Re: MSI GT 75 8rg clip trigger issue need help
Try this: go Composition menu, Beat snap , set it to none.
If that doesn't help, please send us a screen recording of what happens.
DOPETICAL ILLUSION
I have already set beat snap to none nothing worked out.
its a really wierd glitch.
Ill surely record it n send u by today as I'm at a gig ryt now
Thanks Alot
Thanks Alot
DOPETICAL ILLUSION
Cant add an mp4 file for attachment
You can send it to us to mail@resolume.com or upload to youtube or vimeo and share the link for it.
DOPETICAL ILLUSION
i have emailed it just now u can check it out
Thanks for the recording,
it looks like the freeze when you launch a clip in a layer that might have not played for a while.
Menno explains what happens in these cases here: http://resolume.com/forum/viewtopic.php ... =20#p69674
DOPETICAL ILLUSION
So is there a way to resolve it bcuz it looks really messy when i am at gigs and it happens alot specially when working on second display
DOPETICAL ILLUSION
Need help buddy please help
What you can do to have the layer texture kept allocated would be to play a transparent clip in the layer instead of ejecting everything.
That doesn't help with the file/OS buffering, but could give you a small advantage on launching the next clip in the same layer.
