Strobe effect breaks when freq to max
Topic says it all, when Strobe effect's frequency goes to "1.0" it stops flickering. "0.999" still works..
Re: Strobe effect breaks when freq to max
This is normal behavior. Has been this way since I started using Resolume. Just map your shortcut to stop at .999
I have a lot of functionality built around 1.0 and 0.0 doing this. I assumed it’s a feature.mfo wrote: Mon Jul 02, 2018 13:54 Topic says it all, when Strobe effect's frequency goes to "1.0" it stops flickering. "0.999" still works..
of course, that's what i did. still seems a bug to me.Arvol wrote: Mon Jul 02, 2018 16:54 This is normal behavior. Has been this way since I started using Resolume. Just map your shortcut to stop at .999
The extremes of the strobe frequency param are set to be completely off at value 0 and completely on at value 1. This is done on purpose. Think of it as strobing infinitely slow and infinitely fast
If you don't like that behaviour, you can define your own envelope for the frequency param and save that as your preferred effect preset.
