Text problems
Text problems
When I open the text effect when using the program, 6 programs are output. I want support for the solution.
Re: Text problems
I'm not fully understanding your problem. Sorry.
When you add a Text (Animator or Block?) FX or add a Text Animator Or Block Source?
Can you take a screenshot of what it is doing?
Re: Text problems
The program closea when i click on the generator tab
Re: Text problems
Could you please send us your log file via the feedback tab in preferences?
Also make sure to send the crash reports using the reporter dialog that should pop up after the crash with your email address, so we can get a better idea of what happens.
