Strobe problem with multiple layers
pette
Post by pette »
I have layer 5 with alpha clip.
I set this layer in Add so the the layers under 4-3-2-1 are visibles.
If I set the strobe effects in the layer 5 the result is a black strobe effect and I lost the transparency.
If I set other blend mode in layer 5 I have not the effect I want.
So it's my fault?
Re: Strobe problem with multiple layers
On your strobe FX, can you please click on the color picker drop down menu and then click on HSB. Now scroll to the bottom and turn the "Alpha" slider down to 0%. You should now be seeing your layers below your Strobe FX layer.
pette
Post by pette »
Arvol wrote: Thu Aug 23, 2018 14:15 On your strobe FX, can you please click on the color picker drop down menu and then click on HSB. Now scroll to the bottom and turn the "Alpha" slider down to 0%. You should now be seeing your layers below your Strobe FX layer.
Fantastic!
Thanks 8-)
