fps dropdown macbookPro
Chieffcrew
Post by Chieffcrew »
Hello, since release 6.0.11 my Macs (mid 2012 mid 2014) are dropping down the fps to almost 9fps even with DMA force to on, any advice? I just use 2 layers in a simple gig with a video 1 logo and 5 clips 4K.
Re: fps dropdown macbookPro
How's the FPS with the same composition and files in 6.0.10 (or the previous version you had)?
You can get the installer for 6.0.10 on our website.
Go to our download page, and scroll down.
You'll find a "Select Version..." combobox, which has most previous releases.
Select the one you'd like and your download should start.
Chieffcrew
Worked good 60 fps with 3 layers and 15 or 20 deks in 1080p, but now this happens just in my macs in my Alienware works smooth
I guess your Alienware has a much better GPU than any of the macbooks.
How many outputs do you use?
Which version was working good with this same setup on your macbook?
