Win10
GTX 970M
- Set your Output Hz to 50
- Set your GUI Monitor to 60 Hz
- Open a new composition
- Set your comp to 50 Hz
- output to second output (50hz)
- Add source Line scape "Harp Strings" to any layer and trigger it
result: like a clockwork every second it skips some frames
After I set the gui monitor also to 50hz it runs buttersmooth.
You could ask....why would you use different Hz inside your setup? - I don't know
..just guessed that that shouldn't result in a rope skipping situation.
Best wishes
