Sharing/Sending Project
UrqYo
Post by UrqYo »
I am trying to share my project file with my partner who I do visuals with but am not sure how to package it as putting the file on a dropbox type site or a USB will break the links between clips and their location on the drive in which they started I think and trying to re-connect them wont work as the clips only live on one machine.
Is there any way to share or send send the full project with all clips, effects and mapping saved as they are in the original project?
Re: Sharing/Sending Project
UrqYo wrote: Mon Sep 17, 2018 08:22 I am trying to share my project file with my partner who I do visuals with but am not sure how to package it as putting the file on a dropbox type site or a USB will break the links between clips and their location on the drive in which they started I think and trying to re-connect them wont work as the clips only live on one machine.
https://resolume.com/support/en/media-m ... lect-media
