MIDI Speed Assignment
psensibil
Post by psensibil »
Hi, all!
I've been slowly working on transitioning over to Arena 6 from 5 and trying to get my new MIDI assignments to match the behavior of my Arena 5 mapping. I've come across an issue I can't figure out, but I'm sure there is an answer.
In my previous mapping, I had faders solely used for speed control of the individual layers regardless of what layer is selected. In attempting to do this in 6, I try to assign the Speed control in the Clip panel and it seems it wants me to identify the control for each slot as opposed to the layer as a whole. I tried to find a speed control on the layer level, but can't seem to locate it. I am aware of the composition speed slider, but need to control layer speed independently.
Thanks in advance for any advice on how to go about this!
shudder_inc
Re: MIDI Speed Assignment
Post by shudder_inc »
Layer speed is located in the Layer Transport Controls. I think that's what you're looking for. MIDI mapping speed within the clip itself should only give you control over that specific clip.
If I'm remembering correctly the Layer Transport Controls aren't visible the very first time you launch Resolume, use the View option from the menu to select them to be visible.
psensibil
Post by psensibil »
You are my hero. Thank you so much!!!
