Hi everybody,
Everytime i open a dialogue box in Arena 6, resolume crashes immediatly. I can scroll in the box but in task manager it's shown as "inactive" and the cpu usage gets nearly up to 100% then i need to kill the task otherwise the dialogue box freezes and is shown in any other program or even on the desktop. BUT that only happens if i run resolume off my GTX 960 - if i right click the icon and choose the integrated graphics it works totaly fine but is (obviously) not that powerful and it would be a shame if i couldn't use my 960. Whats kind of interesting, if i dont click on any dilogue box and only use the decks and tools it won't crash - but for getting the mapping ready in a venue it's just frustrating.
I'm on a Dell XPS 15 9550 4k:
i7 6700HQ
GTX 960M
16GB RAM
Samsung 2280 NVMe
Windows 10 Pro + drivers are up to date
Here are the logs:
Resolume Arena 6.0.1 60561
Log started: 5 Oct 2018 11:26:08am
Logging has started
Initialise JuceResapiApp
Initialise ResApi
INFO: Created TaskManager with 6 threads.
ERROR: Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
INFO: ---Info main OpenGL renderer---
INFO: Driver Vendor : NVIDIA Corporation
INFO: Renderer Name: GeForce GTX 960M/PCIe/SSE2
INFO: Driver Version: 4.6.0 NVIDIA 416.16
INFO: OpenGL shader language version: 4.60 NVIDIA
INFO: Maximum Supported OpenGL version: 4.6
INFO: -------------------------------
Install default PathParser
Create Application Object
Setting up default composition.
Resapi: setCurrentApplication
Init Colour scheme for user interface
Create LookAndFeel
Set LookAndFeel
Set LookAndFeel
Disable screen saver
Print version info
Major Version: 6
Minor Version: 0
Micro Version: 1
Revision: 60561
Revision string: rev60561
Version string with revision: 6.0.1 60561
Version string without revision: 6.0.1
Print application paths
Executable Path: C:\Program Files\Resolume Arena 6
User Documents Path: C:\Users\Simon\Documents\Resolume Arena 6
Default Data Path: C:\Program Files\Resolume Arena 6\default
Common Data Path: C:\ProgramData\Resolume Arena 6
Common Documents Path: C:\Users\Public\Documents\Resolume Arena 6
Preferences Path: C:\Users\Simon\Documents\Resolume Arena 6\Preferences
Media Path: C:\Program Files\Resolume Arena 6\media
Compositions Path: C:\Users\Simon\Documents\Resolume Arena 6\Compositions
Default Presets Path:
User Presets Path: C:\Users\Simon\Documents\Resolume Arena 6\Presets
Video Effects Presets Path: C:\Users\Simon\Documents\Resolume Arena 6\Presets\Video Effects
Audio Effects Presets Path: C:\Users\Simon\Documents\Resolume Arena 6\Presets\Audio Effects
Video Sources Presets Path: C:\Users\Simon\Documents\Resolume Arena 6\Presets\Sources
Audio Plugins Path: C:\Program Files\Resolume Arena 6\plugins\afx
Video Plugins Path: C:\Program Files\Resolume Arena 6\plugins\vfx
Previews Path: C:\Users\Simon\AppData\Local\Resolume Arena 6\previews
Layout Presets Path: C:\Users\Simon\Documents\Resolume Arena 6\Presets\Interface
Print system info
Operating system: Windows 10
OS 64 bit: Yes
CPU vendor: GenuineIntel
CPU speed: 2579MHz
Number of CPUs: 8
Memory size: 16240MB
System language is: de
Locate preferences directory
Locate settings file
Load Application settings
Install languages
Language test: English
Hello = Hello
Load Swatches into ColorManager
Create ApplicationController
Create AudioEngine
Load AudioEngine settings
Attempting to load VST: C:\Program Files\Resolume Arena 6\plugins\afx\Bitcrusher.dll
Creating VST instance: Bitcrusher
Initialising VST: Bitcrusher (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena 6\plugins\afx\Distortion.dll
Creating VST instance: Distortion
Initialising VST: Distortion (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena 6\plugins\afx\EQ-3.dll
Creating VST instance: EQ-3
Initialising VST: EQ-3 (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena 6\plugins\afx\Flanger.dll
Creating VST instance: Flanger
Initialising VST: Flanger (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena 6\plugins\afx\HighPass.dll
Creating VST instance: HighPass
Initialising VST: HighPass (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena 6\plugins\afx\LowPass.dll
Creating VST instance: LowPass
Initialising VST: LowPass (V1.0.0)
Load SMPTE settings
Setup Effect presets directory
Setup Source presets directory
Create VideoEngine
Load VideoEngine settings
Let VideoEngine scan for plugins
Scanning directory for plugins: C:\Program Files\Resolume Arena 6\plugins\vfx
Scanning directory for plugins: C:\Users\Simon\Documents\Resolume Arena 6\Extra Effects
INFO: Loading plugins took: 0.02766 seconds
Pass Application name to spout
Set thumbnail for capture device sources
Initialize video engine
Register internal renderpasses
Initialize AudioEngine
Opening Windows Audio device: Speakers (Steam Streaming Speakers)
Opening Windows Audio device: Speakers (Steam Streaming Microphone)
Opening Windows Audio device: Microphone (Steam Streaming Microphone)
Opening DirectSound device: Primärer Soundtreiber
Opening DirectSound device: Speakers (Steam Streaming Speakers)
Opening DirectSound device: Speakers (Steam Streaming Microphone)
Opening DirectSound device: Primärer Soundaufnahmetreiber
Opening DirectSound device: Microphone (Steam Streaming Microphone)
Opening ASIO device: Pioneer MIX ASIO x64
Opening Dummy device: Dummy Output Device
Opening Dummy device: Dummy Input Device
Create Composition
Register Composition with controllers
Create ShortcutManagers
Create ShortcutPresetManager
WARNING: ra::File::scanForChildFiles: Could not scan for child files, 'C:\Users\Simon\Documents\Resolume Arena 6\Shortcuts\activePresets.xml' does not exist as directory.
Create DmxController And Load Settings
Set Fixtures Directory: C:\Users\Simon\Documents\Resolume Arena 6\Fixture Library
Create ScreenSetupDriver
Set ScreenSetup Presets Directory: C:\Users\Simon\Documents\Resolume Arena 6\Presets\Advanced Output
Load ScreenSetup Presets
Create AdvancedScreenSetupWindow
Set ScreenSetup Advanced Preferences file: C:\Users\Simon\Documents\Resolume Arena 6\Preferences\AdvancedOutput.xml
Enumerate displays and position MainWindow on primary device
Init Screen Setup
Register application specific renderpasses and sources
Load video effect presets
Load audio effect presets
Load VideoSources presets
Create MainWindow
Create MainComponent
Install KeyListener
Install MouseListener
Create UI manager
Set set Update Accepted Callback
Attach menu to window
Load auto-saved layout
Show main window
Set fonts
Looking for unicode font
Unicode font found is: Lucida Sans Unicode
Language file font setting: FontToRenderThisLanguageInWin
Language file font base height setting: 0.00
Create HelpController
Load HelpController file
Loading help file, path: C:\Program Files\Resolume Arena 6\docs\help\English.xml
Create OscController
OscController: Install Translation Strategy
Load OscController settings
Create MidiController
Refresh MidiController
Load MidiController settings
Start MidiController
Resapi Frame Cache
Create renderer
Start renderer
INFO: Reading composition state took: 0.17004 seconds
INFO: Initialise took: 2.95535 seconds
OpenGLCanvas: New context is created
rj::ArtNet::initialize: Could not create ArtNet node.
rj::ArtNet::initialize: ArtNet Error, Cannot find adapter ethernet_32772
Log started: 5 Oct 2018 11:26:32am
Logging has started
Initialise ResApi
INFO: Driver Vendor : Intel
INFO: Renderer Name: Intel(R) HD Graphics 530
INFO: Driver Version: 3.2.0 - Build 21.20.16.4664
INFO: OpenGL shader language version: 1.50 - Build 21.20.16.4664
INFO: Maximum Supported OpenGL version: 3.2
Create LookAndFeel
Set LookAndFeel
Set LookAndFeel
Print version info
Major Version: 6
Minor Version: 0
Micro Version: 1
Revision: 60561
Print system info
OS 64 bit: Yes
CPU speed: 2580MHz
Number of CPUs: 8
Install languages
Hello = Hello
Create AudioEngine
Load SMPTE settings
Create VideoEngine
INFO: Loading plugins took: 0.02862 seconds
Create Composition
Init Screen Setup
Create MainWindow
Install KeyListener
Create UI manager
Show main window
Set fonts
Resapi Frame Cache
Create renderer
Start renderer
INFO: Reading composition state took: 0.23402 seconds
INFO: Initialise took: 2.87952 seconds
Resolume Crash on GTX 960
Re: Resolume Crash on GTX 960
Could you try updating Resolume to the latest 6.1 and check if the same happens?
You can get it from our download page.
