Merge compositions
elgarf
Merge compositions
Post by elgarf »
I'd like to have ability to "merge" two compositions into one:
1) currently opened composition is "main", all settings, effects on composition, etc. stays as in the main comp.
2) then I want to import all decks into "main" comp from another composition so...
3) I select "Composition=>Merge" from menu and just locate my second composition.
At the end I have decks from both main and merged composition.
Re: Merge compositions
You can drop decks to your existing composition from the Composition panel.
Doesn't that do the same?
elgarf
Post by elgarf »
Looks like exactly what I want. Thanks!
