1080TI only 20FPS
e23415
1080TI only 20FPS
Post by e23415 »
comp size 7680x2920, got only 20FPS when 3 x 4K output enable.
3 x 4K output + 2K GUI
i7-7820x
ASUS WS X299 Pro/SE
32g DDR4 3600
Samsung 970 EVO M.2
1080TI
been surfing the forum with most the keyword i can think off, and still got nowhere to improve the FPS ;( any input would be welcome!
Empyfree
Re: 1080TI only 20FPS
Post by Empyfree »
What’s the content?
e23415
Post by e23415 »
Content is on DXV3 format same as the comp size. and 4K also.
A few questions for you:
  • How is your comp built?
  • Is all your content 7680x2920?
  • How many active layers at once?
  • How are you breaking down your comp in the advanced output?
e23415
Post by e23415 »
Things turn better after using the old nvidia driver from March 2018. Output on 3 Screen, content on comp size. im now able to run at about 30FPS, which is all i need!
now im on the next task for 7680x5400 with 7 output, is that even possible on 1080TI machine to run smooth at 30FPS?
e23415 wrote: Sun Oct 21, 2018 18:21 Things turn better after using the old nvidia driver from March 2018. Output on 3 Screen, content on comp size. im now able to run at about 30FPS, which is all i need!
I personally lock all my comps at 30fps especially when I work with Datapath X4 or FX4s.
you may be limited to just a few layers when you get into that size comp but you should be able to get something stable.
