Hello everyone, first of all sorry that i have not been very active on this forum recently it has been a bit busy.
before i make the mistake again to put something on fb, i would like to share my results with alley and C4d.
In the link you can find the tiff images c4d makes from a animation. and somehow (it could be me) I cant make it in to a dxv movie. in adobe encoder there was the option to say this group of images are together a images sequence
https://drive.google.com/open?id=10Ue4q ... 7BBKoztTTy
greetings
Alley Tiff images to movie
Re: Alley Tiff images to movie
The trick is to drag the folder containing the sequence instead of the individual files, that way Alley can detect you want to use the files together as a video.
There is something funky about these .tiffs though. Alley either crashes on import or only converts the first frame and then crashes.
We'll see what we can do to improve that. Great test case! Where were you during the beta
