Hi all !!!
Is there a way to record advanced output of multiple slices within Resolume?
many thanks
simon
Output Record Doesn't Record All Slices
Re: Output Record Doesn't Record All Slices
Duplicate the screen and then send out via spyhon to syphon recorder.
thank you!
will try that now.
will try that now.
hmmm - see SPOUT but now SYPHON as a choice on the duplicate... separate piece of software must download? thank you again!
ah ok - SPOUT is win 10 version of syphon...
spout recorder is the same as syphon recorder?
