One Projector Multiple Screens
highstreetpictures
Post by highstreetpictures »
First showing of our installation tomorrow using just one projector. I have set up multiple screens for multiple projectors for the actual performance and was wondering if there is a way to fade/transition between screens in the advanced option?
Reason - using slices to divide up each screen differently // would like to transition between each screen back and forth if necessary. ty !!! simon
Re: One Projector Multiple Screens
Check out Slice Transform
highstreetpictures
will do - thank you.
