Takeover mode
inzieye
Takeover mode
Post by inzieye »
is it possible to add a "takeover mode" for midi settings. Like in Ableton Live.
Maybe it's not possible, maybe it's not a priority, maybe it will coming soon?...
And if I say it's the only missing option in Resolume?
He2neg
Re: Takeover mode
Post by He2neg »
I dont know Abalton live so i dont know what the "takeover mode" is doing.
But you may will get a respond from some1 who know this and can tell if its somewere hidden oder what is a possible work around to get what you want.
Or you may be so kind and explain it to all the non abalton users here ;)
~Berlin~
inzieye
Re: Takeover mode
Post by inzieye »
Good advice,
The "takeover mode" is Midi setting, you can choose between 3 modes :
None — As soon as the physical control is moved, its new value is sent immediately to its destination parameter, usually resulting in abrupt value changes.
Pick-Up — Moving the physical control has no effect until it reaches the value of its destination parameter. As soon as they are equal, the destination value tracks the control’s value 1:1. This option can provide smooth value changes, but it can be difficult to estimate exactly where the pick-up will take place.
Value Scaling — This option ensures smooth value transitions. It compares the physical control’s value to the destination parameter’s value and calculates a smooth convergence of the two as the control is moved. As soon as they are equal, the destination value tracks the control’s value 1:1.
I would like to use the Pick-Up mode.
He2neg
Re: Takeover mode
Post by He2neg »
I would love to have the pickup Mode as well... and no i dont know any workarounds...
When you change your value and then touch fader it jumps to the new value.
Unless you use midi / osc out and your interface can handle it as well... Then all values on all devices will allways be in sync
~Berlin~
drazkers
Re: Takeover mode
Post by drazkers »
Would be handy between devices for sure!
I created this in touch designer taking in 2 midi devices and artnet.
It was not computationally easy with python tho, I had some fps issues.
inzieye
Re: Takeover mode
Post by inzieye »
Thank you for your answers,
I'm using TouchOSC and Lemur too but I need some more "physical" control for specific effects and I don't want to use as much controllers as effects that I use.
So I need to control different parameters with the same physical button (fader, rotary...) and when I switch between them, values jump to the physical position of the button. Sometimes it's not a problem but generally it looks dirty visually.
Mainstage (Apple music software) propose the same function. So maybe it will come in Resolume one day.
