Rename the Slice Transforms effects
djrummer
Post by djrummer »
Hi. Me again.
I would love to be able to rename each Slice Transform Effect so I know what slices are in there.
I realize i can midi map, etc...
just a request.
Re: Rename the Slice Transforms effects
Workaround for now:
Create a new layer, insert video router grabbing your comp, add slice transform fx to layer router, add text block to a layer below and label it to your liking, play layer block and update video routers thumbnail, delete text block.
Rinse and repeat the above steps (minus creating a new layer) and then just map your video router as if you would your slice transform fx.
djrummer
Post by djrummer »
iiiiinteresting!
I totally understand that flow. Funny, I'm also trying to consolodate / collapse my layer count... but this might be worth adding another layer for.
I had someone build me a Max 4 Live device that works as a radio group / Matrix , and that works. but this is even more visual!
i like.
Thanks for the input!~
-Vince
