Hey guys,
I am new to Resolume and currently working on mapping my visuals to a AKAI APC40 MkII and everything went well so far until I tried to assign different effects to different layers with the same buttons. Attached you'll find a picture what I tried to do. I would be super pleased if you can help me out asap because I am running out of time.
Best regards
Tobias
MIDI Mapping APC40 MKII issue - Multiple fx same button
Re: MIDI Mapping APC40 MKII issue - Multiple fx same button
Assign shortcuts to the layer dashboard using the "Selected Layer" target.
https://resolume.com/support/en/midi-sh ... cut-target
Then assign effect parameters to the dashboard as desired.
https://resolume.com/support/en/dashboard
Hey Joris,
sorry for the late response.
Thanks alot for your fast description.
Everything runs perfectly now!
Many thx for your help
Best regards
Tobias
Best regards
Tobias
