I've been using a lot of gear in the passed, but I'm looking for updated camera versions / options for the following 2 situations I want to create - please help if you can;
1.
What is the best camera-setup / situation, for tracking the movement of a group of dancers on stage? I used to work with a simple infrared IR-camera setup front-of-house. Have the light design on stage, strengthen a "backlight" to make the dancers pop in front for to make a "silhouette image". Is this still the best way to get a black-white video input, with least amount of latency, to use as movement-matte (in TouchDesigner and/or Resolume)? Or are there other types of simple-setup cameras to get the general movement on stage as input...? (If infrared is still the best option: any direct links to European shops online to buy a stable ip-version IR-cam with least amount of latency?)
2.
I'm looking for the newest "on body camera" with least amount of latency and stabilising on-board; to have 1 dancers on stage wear it and send the video-image wirelessly to front-house (as video-input into Resolume and/or TouchDesigner). What about the GoPro HERO5/6/7black or the DJI Osmo Pockets...? And run it through a WiFi router on stage - any experiences? And/or other cams out there /gear that can pull this off simply and beautifully? (720P should be fine, 1080P even better... Black and white image might even do as well and/or any infrared camera options out there... (cool effect)?).
All updated 2018 / 2019 info is very welcome!
Thanks a lot in advanced !
- Ruben
r u b e n [AT] r u b e n v a n l e e r . c o m
