some bugs
hijack
some bugs
Post by hijack »
1. it was very nice idea to have this new fature with midi mapping so now you can move sliders with midicontroller from the same point even if you changed the value with mouse however when im setting the knobs for opacity on each layer with endless value its not working with freeframe mixers,it stucks in one point...its only with 2 input mixers but with the rest it seems to work fine.
im using Evollution X-session.
i really like this option.and this new step frame for layers option.it works the same even if i turn left or right the knob ,so there is no problem with the knobs that were moved to maximum value...i dont know if i made myself clear enough...
2.still have the same bug from earlier versions with the plugins list.
when you open effect list its not showing the whole list of plugs,you have to close and reopen freeframe folder to have the rest of the list...its annoying a little..
3.tracker source plugin works strange..its pretty unusefull in that form.you cannot reset the drawing with the parameters and it starts to draw lines when you want to change the value of pen...and even if you change the width to 1 its not remembering it.its still drawing with the start width...but in the deck preview it looks like it changed but somehow in preview window its still the same...
4.i had also problems with VVarp 2input plugins,but he made the new version of them and now everything seems to be fine.
but sometimes some plugs arent shown in resolume and once i had two times one plugin in the list.
also happened once that there were no titles shown for the effects parameters,but after reopening Res everything was ok again.
thats all/you are doing great job anyway.thanks
hijack
tracker
Post by hijack »
this time it works.i can change the width and RES remembering it,but mouse moves on Y axis are inverted....
edwin
Post by edwin »
hi just a quick note,
this tracker plugin should not have been in this final release.
it was just a test, so yes it is not very usefull..
edwin
[Edited on 5-8-2005 by edwin]
