Not Responding to Midi CC
DocYates
Post by DocYates »
I am new here, so here we go.
I have resolume 6 on my macbook pro laptop, the clips are triggered via Midi CC input from a program called show buddy thru my IAC driver
works perfect
It also triggers clips from midi input thru pitch wheel on show buddy - also works perfect.
For show purposes I put resolume 6 my mac desktop to ease the burden on the laptop.
I send the midi cc messages thru the midi studio network via a thunderbolt cable from my laptop running showbuddy, to my desktop using resolume
I have selected the netowrk as the midi input on the desktop
It shows that all of the messages are being received in the midi preference window every time which great.
However, that message is not always triggering the clips which have the same midi shortcuts put on them as I did in my laptop. Sometimes it triggers the clips, some clips it never trigger, some clips will trigger and then not turn off.
If I manually click on the clips on my desktop they will respond, but I need them to respond to the midi input I have assigned to them
thank you
