Hi Guys,
I am new to this forum. Hopefully someone can help me with my issue.
I want to control Resolume Arena with my AKAI MPC LIVE. On youtube I'v seen somebody doing this but the guy is using ableton and then rewiring it to Resolume. I don't want to use ableton. So I hooked up my MPC in controller mode and I started Arena. And the MPC is visible in the Midi prefs (though I had to start the MPC software first). I checked the box MPC Live Port One; Midi input. But if try to assign the drumpads to the resolume clip via Edit Midi, resolume doesn't react. It doesn't see an incoming midi signal.
I tried the same with my m-audio midi man 2X2. The advantage is that i don't have run the MPC software in the background. But the result is the same; resolume doesn't see any midi signal coming from the MPC.
So is the MPC not compliant or what can I do to make it work?
MPC LIVE
Re: MPC LIVE
Be sure to install latest MPC driver, if not..
Try to use this Cable
https://www.amazon.com/Cable-Interface- ... s=midi+usb
I'm not a professional, but trying to help
Re: MPC LIVE
thanks for helping! I hook up the mpc to my mac with a usb cable, so the midi is running through this. I don't think i need a cable because the software of mpc receives midi notes.
