Not entirly sure if this is a problem but I thought the feedback source would work like regular layers, ie only affecting those below it but it appears to affect the layer above it too.
What can I do if I want to key, say, some graphics or text 'clean' on top of the feedback-ed layer below? Just now they get feedback-ed as well...
ALSO
When using zoom as a global effect to resize my output, this too has an effect on how the feedback effect works. For example if the output is reduced while using feedback+Ad the result might look fine but when I remove the zoom effect the feedback effect bleaches out the output. ie, global effects affect how the feedback source, in itself , works.
Not sure if these are really 'bugs' but that's what happened anyway.
Feedback source bugs?
the fead back effect doesnt 'effect' all layers, al it does is take the output from resolume and feads it back into that layer, hmmmm i wonder what it would work like if you had multipule screen outputs.
bart edwin... what would happen if you have 3 outputs, one of the GUI, one with full 3 layers with effects, and another one with just layer 1?
