Audio lag
lightmaster
Audio lag
Post by lightmaster »
Hi
I am struggling with lag on some of the videos I play, I can play the same video in q-lab with no lag but in resolume Arena 6.1.1 it will start lagging after about 2 sec.
I am running on a MacBook Pro (Retina, 15-inch, Mid 2015)- 2,2 GHz Intel Core i7 - Intel Iris Pro 1536 MB - 16GB
This is a recurring problem with other MacBook also.
Any advice on this?
pfelberg
Re: Audio lag
Post by pfelberg »
A first step: audio should be flat, no compression at all, within videos playing in Resolume.
Re: Audio lag
Are you using uncompressed (pcm) audio in these video files?
lightmaster
Re: Audio lag
Zoltán wrote: Fri Jan 04, 2019 13:19 Are you using uncompressed (pcm) audio in these video files?
Hi
I have converted a .m4v with H.264, AAC to dxv
it is basically a video recorded on a phone.
Re: Audio lag
Does the video also drop frames/flash to black occasionally?
Have you tried to change the audio buffer size in audio preferences?
Do other Audio files play fine in the same layer?
Could you send us this DXV that has this issue and your original file so we can check them out?
Which program did you use to convert the m4v to DXV mov?
lightmaster
Re: Audio lag
Zoltán wrote: Fri Jan 04, 2019 16:42 Does the video also drop frames/flash to black occasionally?
Hi Zoltan
The video seems fine, no drop frames.
I have tried changing buffer size, I can send this DXV if you mail me. I used MPEG Streamclip to convert.
Re: Audio lag
lightmaster wrote: Fri Jan 04, 2019 18:35 I can send this DXV if you mail me. I used MPEG Streamclip to convert.
Sent you a PM ;)
Re: Audio lag
Thanks for the files, the DXV works fine for me on my macbook.
Try adjusting the audio buffer size to something higher.
If that doesn't help, try to record how the lag sounds and looks like exactly so we can better understand the issue.
