Wireless Sony Z90 streaming and NDI issues
Hakol.Sound
Post by Hakol.Sound »
Hi Folks.
Is it possible to stream Sony Z90 feed directly to resolume?
Whats format does it streams?
Another Q,
Do you get reasonable performance when using wireless NDI feed from iPhones?
Re: Wireless Sony Z90 streaming and NDI issues
Hakol.Sound wrote: Sun Jan 13, 2019 12:34 Do you get reasonable performance when using wireless NDI feed from iPhones?
Yes but it helps to have a dedicated wireless network.
deflost
Post by deflost »
hello. we work with a ndi only wlan (fast as possible) from a gigabitrouter. we route up to 12 ndi (iphone 6-10) into resolume und mix/ switch them for diffrent show purposes. works stable and fast enough in most cases. ca. 4-12 ms delay, but allways sycronized audio and video!
in some situations when the audience is more then fiffty people with 2.4 ang 5 g wlan or/and g3-5 activated, there are some recognizable lags and some short dropouts. but in the hole, we love ndi......
r.h.
westfernsehen, leipzig
