Conductive Bareboard MIDI is making Resolume 6 Not Responding
saqib.vision
Post by saqib.vision »
I have one touch base conductive bare board , whenever I plugged-in the device and same time Resolume 6 become Note responding and as soon as I did unplug the device, software become normal for use.
By the way, two days ago I have used it successfully but after that it is giving me similar behaviour of not responding.
Please let me know or assist how I can fix this issue, I need to decide which software I need to use for my project and purchase the right product.
Re: Conductive Bareboard MIDI is making Resolume 6 Not Responding
What's the rate of midi messages the board sends out?
If it's sending constantly, try limiting the rate.
Try disabling any midi outputs you might have active to be sure to avoid feedback.
Has anything changed in your setup between the time it worked and it broke?
saqib.vision
HI, I need help,
Another application Madmapper is working fine and smooth but I like and want to use Resolume as it is more friendly and rich and managed well in contents order.
How I can get help.
I tried to remove everything which is extra on my machine but no success
How many midi messages is the board sending per second?
What kind of midi messages are you sending exactly?
jahancocks
Post by jahancocks »
Did you find a solution to this problem, have the exact same issue?
James
