DXV output 1Gb size
moha20106
DXV output 1Gb size
Post by moha20106 »
Hi all,
I have big problem with DXV codec
I have installed Adobe After Effect 2019 CC
I have installed Adobe Media Encoder 2019 CC
I have installed Quick Time Pro
I have installed Resolume DXV Codec 3.1
I can't find DXV codec in Adobe Media Encoder (quick time format)
I found the DXV3.qtx file in qtsystem folder, in Quick Time install path
But no way to find DXV codec in After Effect output
If i trying to encode using Quick Time Pro, the file output come over 400mb size!
When the source file is 16mb size!
If i trying to encode using MPEG encoder, the file output come over 1gb size!
What damn going on?
I went to buy all these programs and spent alot of money
Still haven't Solutions for DXV encode
Anyone help please
He2neg
Re: DXV output 1Gb size
Post by He2neg »
Alley is working fine for me...
https://resolume.com/download/
~Berlin~
First off, DXV3 is an uncompressed codec, so files sizes are going to be very LARGE.
That's why they play back so silky smooth.
In the newer versions of Adobe, the DXV3 codec will be listes just as DXV3 and not under quicktime.
If you install the latest version of Alley, it will include an auto installer of the codec for Adobe if you choose that option.
OR
You can convert to DXV3 for FREE using Alley.
moha20106
Post by moha20106 »
He2neg wrote: Fri Jan 25, 2019 12:00 Alley is working fine for me...
Thanks dear for your reply, there's no codex coption in alley
moha20106
Post by moha20106 »
Arvol wrote: Sat Jan 26, 2019 01:39 First off, DXV3 is an uncompressed codec, so files sizes are going to be very LARGE.
OR
Theres no convert option in Alley, how to use it?
Arvol wrote:DXV3 is an uncompressed codec
At the risk of being pedantic, DXV uses two compression steps. The first is lossy intraframe compression on the image, similar to how JPEG compression works. The second is a lossless compression step on the data itself, very similar to how ZIP works.
It just performs so insanely well during playback because we let the GPU handle the decompression.
moha20106 wrote:Theres no convert option in Alley, how to use it?
Make sure you're running the latest version and then follow these two easy steps: https://resolume.com/support/en/convers ... two-clicks
