How to program pad lighting for Launchpad Pro?
A_Face
Post by A_Face »
Hi everyone,
I just got a Launchpad Pro and as far as functionality it's working fine. I'm pretty much just using it for clip triggering and then putting all my effects and layers on my APC MKii. The only thing I'm not able to do is program the pad lighting. I'd like to just have a really simple layout where all my inactive clips are blue and all my selected ones are magenta. I've tried messing around with the velocity settings without success. It is lit up now, so I know output is enabled, but it's just using the generic C scale default map. Not a big issue, but it would be nice. It seems like I may need to do it in Ableton but I feel like that can't be quite right...?
Re: How to program pad lighting for Launchpad Pro?
You can set the midi velocities for the different clip states. have you set these to different velocity values?
Are you using the same notes the launchpad sends mapped on the APC?
