my audio analyser crashes nearly everytime, i want to control a flash-movie with the equalizer-variables..
the eq's look sometimes just like frozen.. allthough sometimes the eq-variables still seem to reach the flash-file....
A little workaround
By coincident i found a little workaround.
When the audio analyzer stops working, go to preferences, select a different audio-source (you should have at least 2 sources: your audio-driver and windows pimary input) select the other one, click ok, than select your input again. Voila, the audioanalyzer works again (until next crash).
After some more intense testing i can definitely say:
I now have this bug in older Resolume versions too. But i don't remember having experienced this bug when i was using Resolume 2.2 . In that time i used Flash pro 7.01.
So the bug might depend on Flash8 or - as Orjo wrote - the bug happend since Flash professional 7.2.
Does that make sense?
[Edited on 27-1-2006 by mfo]
