firewire out for a decent record?
does anyone know if you can get a firwire output of a resolume mix? i want to get a decent recording of some of a mix and find the 'record' feature to give only jerky results. The other option Ive tried is recording the video out but again the loss of quality is too much. any ideas anyone? cheers
continuity-B
Yes, DV means some sort of reformatting the video-data. But DV is close to uncompressed -as far as i know. So this operation should consume almost no cpu power.
This would be a very nice feature for Resolume, because recording the video output with a DV-cam does indeed lower the quality of the pictures, especially at the borders.
(Of cause, s-vhs will do better than composite.)
well if you want to record VGA you will have to get a bit of hardware that can record VGA, such as the first google result http://www.epiphan.com/products/vgarecorder/index.php but that will cost you a fair bit... you would be better off with a DVD recorder and a SVideo cable... of if your video card has it, component.Originally posted by ocean
Personally i dont like using any video signal at all unless i have to. im used to using the vga-out for projectors. Ideally its this signal that i want to get a recording of. any thoughts?
another possibily - with much lower costs than those vga-recorders, but still quite expensive - is this baby, the world's only scan-converter with vga-input and dv output:
http://www.canopus.us/US/products/TwinP ... act100.asp
Anonymous
Hi guys, to record a master of a mix in resolume!!!
I have done it using an avermedia pc to tv converter. I used this thing to split the vga signal, sending one to the projector and one to a dvcam and recording in to a minidv tape. Here take a look http://www.aver.com/products/comptv_QuickPlay.shtml.
See ya all
See ya all
