HI,
there are SWF-->FLA converters on the internet that do a pretty good job at "decompiling" swf's (since they are not compiled at all) ive tried it with a trial version and it sees the code but i dont know if its correct because i cant export it in the trial...
so what u could do:
save the swf. or if you cant save it, use an app to save it from your cache to you desktop (for instance).
then "decompile" it.
use the code and the movies to build it again.
some pretty heavy AS in that swf by the way, so if you try it be ready for some serious thinking... saw some AS inverse kinematics which impressed me if im not mistaken.
oh yeah and the owner of the swf could get pretty pissed
if he found out youre "decompiling" his swf
good luck,
SuperficiaL
[Edited on 25-8-2005 by SuperficiaL]
