A friend asked me to help them with a build.
They do large events and want to use the computer for running many large 2k led panels.
Would this build run resolume well and last a few years?
Also, Would any parts need to be upgraded or downgraded?
Here is my current parts list: https://pcpartpicker.com/user/GateBreaker/saved/LL3P3C
Build Suggestions
GateBreaker
Re: Build Suggestions
Also, Should I go with a atx or micro-atx or mini-itx motherboard?
xdjxklusivex
Processor - good
Cooler - eh, I have been using the corsair h110i in a matx case and it runs great.
Board - good, If space isnt an issue I would go with ATX for future expansion
Ram - I prefer corsair, its been good to me for years. 1x16 is good leaves you room to expand later.
HD - NOPE, moving rig I would not use a conventional HD. Go with m.2 for speeds at the bare min a standard SSD
GPU - GOOD
Case - Personal preference, I went with a matx cube (air540 to be specific) due to size constraints. I fit my whole setup in a pelican case so it works out well for me
PSU - Will do the job
GPU - GOOD
