Hi!
Do you have any plans on making it possible to change the layer transition times as long as you want? In most of my setups 10 seconds is too short.
Would help a lot!
Anton
Longer transitiontimes
Re: Longer transitiontimes
Take a look at this short tutorial as it might help you out:
Thanks, it just feels like unnecessary time consuming if you have a lot of long transitions instead of being able to change the overall maximum transition time in the settings or something.
Anton
Anton
