loss of effects/generators in 1.1beta2
mr.shintla_
Post by mr.shintla_ »
hi
after some days of use i recognised, that the list of generators is empty. i know i used some of them before.
how did that happen, or is it a bug?
greetings.mr.shintla
sould like a bug you should have more more effects is the rest if the txt visible in the interface?
mr.shintla_
jes. everything else is visible. expect the effects!
mr.shintla_
this happens only in the beta2. in version1.0 everything is visible. it even makes the scrollbar longer when i click the 1.time on generators, but nothing gets visible. it looks like it loads the effects. but noone appears in the list. even after removing&reinstalling...
mr.shintla_
solution: delete that fot1.fff from the resolume prog dir.
sensual vibration_
Post by sensual vibration_ »
I only find prefsuser.fff and shorts.fff !
