Expand resolume UI to two monitors
moha20106
Post by moha20106 »
Hi all,
Im looking for the way to expand resolume user interface to two monitors
For example : 1st monitor for normal UI
The 2nd monitor for playback windows, layer tab, or editing tab
Anyway to add this feature?
Re: Expand resolume UI to two monitors
Have you tried to size the Resolume UI over to your secondary display?
moha20106
Post by moha20106 »
Zoltán wrote: Thu Feb 14, 2019 11:09 Have you tried to size the Resolume UI over to your secondary display?
I read your reply, went to do it
Still the layers height small and kill half of the 2 screens
The playback monitors (bottom-left) still small
Do you know, i need one screen monitor for layers only, and the 2nd one is for playback and tabs (editing..etc)
Empyfree
Post by Empyfree »
Are you on Arena 6? If so you can rearrange the panels, to suit your preference. Put all the layers on the left or right hand side of the screen, stick the previews st the top etc.
moha20106
Post by moha20106 »
Empyfree wrote: Fri Feb 15, 2019 07:31 Are you on Arena 6? If so you can rearrange the panels, to suit your preference. Put all the layers on the left or right hand side of the screen, stick the previews st the top etc.
Thanks dear for your reply
Grimm90
Post by Grimm90 »
How does this affect performance ? Will it eat a of resources or barely noticable ?
Grimm90 wrote: Fri Feb 22, 2019 07:09 How does this affect performance ? Will it eat a of resources or barely noticable ?
Shouldn't be more heavy than having the GUI run at double size vs half size.
